-   -   Bank 2 sensor 2 Codes codes Gas milage!!! (https://isuzuforums.com/forum/rodeo-17/bank-2-sensor-2-codes-codes-gas-milage-37172/)
Blackman_in_a_Rodeo Feb 2, 2011 05:09 AM
Code (P0161) Ive changed the o2s reset the check engine light and for some weird reason its back on?Number 2 code p0440 Evap emission??Whats that lol?Thanks if somebody could help!!
billdarr Dec 2, 2019 04:58 PM
I'm generic... new to Isuzu... However, Evap is a solenoid and has a vacuum source from manifold through the solinoid to the gas tank vent... i suspect no voltage or open coil on the solenoid.
I hope this helps you.
Bildarr ... in AZ
