-   -   AC & Heater Fan problems (https://isuzuforums.com/forum/rodeo-17/ac-heater-fan-problems-312/)
gwarren44 Feb 17, 2006 11:35 AM
For some reason the AC and the fan will no longer come on. I check the small fues and they look ok. How do I check the bigger box fuses?
Also, any other suggestions to find the problem?
It's my daughter's so I don't know what happened to cause it not to work, other than she never turns it off.
thanks,
glen
ISUZUGURU Feb 17, 2006 05:02 PM
replacethe blower motor an the resisitor.or try tapping on the bottom of the heater fan sometimes the sieze from wear an tear,it s right underneath the glove box
Gizmo42 Mar 2, 2006 01:59 PM
Are there any dash lights on?
Blower motor not working along with brake and/or charge lights on the dash is a classic sign of an alternator going bad.
If there are no dash lights then go with what the guru said. Just thought I would throw that in there.
ralph08 Mar 13, 2006 08:36 PM
try to check your
<a href="http://www.innerauto.com/Automotive_Systems/A~c_Heat_System/" target="_blank">a/c
and heater fan</a>, it might need some replacements.
gwarren44 Mar 15, 2006 01:25 PM
Thanks for all your suggestions. IT turned out being the relay. The motor was fine. Seems she had it on, the car was running, got back in and tried to restart the car. For some reason instead of blowing the fuse the relay went.
glen
