ABS Sensor?
Hi all, need a little info/help.
I have (i`m in the UK) a 1999 Vauxhall Frontera 3.2 V6 Auto, which is basically the same as a Rodeo, Trooper etc.
Question is, does the Rodeo or any of the Isuzus have a Multi Info Display? (onboard computer)
Reason is, i need a new off side (passenger side to you) ABS sensor, which has the brake pad wear sensor wiring built in.
Had one on backorder from Vauxhall UK for 6 months, with no definate delivery date!
Thanks
Thanks
I can tell you that the '99 Rodeo LS 3.2L V6 4x4 didn't come with a Multi Info Display and that there is no electronic brake pad sensor. I don't know of any US '99 model that had that technology but there might have been one haven't heard about.` My Hayes service manual doens't have any reference to one in any of the models.
Do you know who made the system? You might have more luck from that direction in finding other vehicles that used the same part.
Good luck finding what you need.
