ABS issue
1995.5 Isuzu Rodeo 3.2L 5sp.
Where is the RrABS http://www.automotiveforums.com/vbulletin/showthread.php?t=1081256# located? I couldn't find one so I disconnected the electrical connector from the ABS pump by the battery http://www.automotiveforums.com/vbulletin/showthread.php?t=1081256#. That solved the problem I was having with the brakes clicking when I was almost stopping. However, now I have an ABS and brake light on as well as a dimly lit battery light. I know I could pull the bulbs but is there a way to put a jumper wire in the electrical connector to make it think it is still plugged into the ABS pump? There are four wires on the ABS pump plug. |
