99 Rodeo, Gas Smell but No Leaks
My 99 Rodeo (3.2L V6) had an intermittent gas smell in the engine and cab, and rough idle. I replaced the EGR, IAC, PCV and Fuel Filter. Runs smoother now, but gas smell has become constant. I do not see any gas leaks anywhere inside the engine or out. I have read different comments on it being leaks in the Injectors, the Fuel Vapor Canister, Vapor Solenoid or Fuel Pressure Regulator. Before I go spending any money on these I wanted to see if there were any ideas out there. Thanks.
