< src="http://www.google-analytics.com/urchin.js" =text/> </> Hi, This year I have replaced just about my whole front end. The brakes/rotors, pads, fluid, balljoints upper/lower, both bearing inside/out with seal, front/rear shocks, U-joints, drum brakes, rack&pinion, but really the only thing is my front anti-sway linksand tie-rods. Replaced on my own. The lugs are bad, this might be the noise, but don't feel with steering wheel. Okay, the problem is when I go any direction steer any direction anytime of the day!!! Happens sometimes in the rear. My lugs are so bad that I have to tighten them on with tools. But they tighten the wheels on. I have double checked the bearings. When I did an aligment they said the tie-rods are OK. I all so think the same the studs don't move when steered back and forth. Anyone Thanks for any info!!! Jamieson < =text/> _uacct = "UA-939292-44"; urchinTracker(); </> |
