95 rodeo will not turn over
Last year I had the clutch master cylinder replace by a "backYard" mechanic and he had cross threaded the line on it. He claimed to fix it and I went on my way. About a month later I completely lost my clutch pedal, to the floor it went. I had a friend bleed it for me and got my pedal pressure back up. This lasted about 2 months and it happened again. I left my rodeo sitting through the winter in hopes of getting the master cylinder replaced completely. When I went to try it again it wouldn't turn over. You turn the key and nothing happens. I get all the dash lights and everything inside works except the heater blower. So I have replaced the clutch safety switch thinking it may have been that. I removed an alarm that was installed thinking that was it since it had sat through the winter. I have checked all fuses and they seem to be good. IDK what else to check? Any suggestions would be greatly appreciated. I have not tried to cross the starter b/c I do not know where it is. The battery is strong, I have tested it and even put in a different one to be sure. Please help!!
