My girlfriend just purchased this 95. It seems to be a great vehicle so far...only had it a couple weeks. The only issue we seem to have encountered is with the door locks. Drivers side, that unlocks all the doors with the key, is very difficult to get the key in the correct position to turn it. I have sprayed wd-40 in the lock assembly a few times to ease this issue but it seems to return relatively quick. Same with the passenger side. As for the hatch, I can't even get the key in the lock. I am assuming that there is a broken one in there or something. Has anyone encountred a problem like this and or should I just look into replacing all of them. Any advice would be appreciated, this is an annoyance more than anything. Thanks. Oh and also can a aftermarket keyless entry system be hooked to this so we don't have to lock the doors with a key when we get out. thanks again. < src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-44"; urchinTracker(); </> |
< src="http://www.google-analytics.com/urchin.js" =text/> </> you dont have to lock the doors with a key you have to hold the handle up when you shut the door < =text/> _uacct = "UA-939292-44"; urchinTracker(); </> |
