-   -   94 Rodeo (https://isuzuforums.com/forum/rodeo-17/94-rodeo-2376/)
Dano Oct 3, 2008 06:57 PM
Just bought a 94 Rodeo, CHEAP, so it really needs some work. First, the turn signals don''t work, either side, no clicking , nothing. Checked the fuse, was good. Checked bulbs, good. Whats next?
Also, I can lock, unlock the doors, but the fronts will only open, the rear glass will also open, but not the rear doors our the rear hatch? Crazy!
Dano Oct 5, 2008 06:52 PM
C''mon guy''s, I gotta get this thing going alright before snow flies here in the North U.P.
Where is the flaher located on the 94 Rodeo? I noticed it is clicking really fast now.
tgor Oct 5, 2008 09:34 PM
Well if you are hearing the flasher blink real fast then you may have a bad bulb there may be up to three bulbs per side two up front (one on the fender and one in the bumper) and one in the rear. If one bulb is out it make the rest blink fast.
As far as the doors not opening you''ll probably have to pull the inner door covers. which won''t be easy with out them open. The rear hatch may need oiled in latch area. When the tire mount is in place it prevents the rear hatch from opening. If the mechanism is seized it could be causing you problems.
Hope this helps.
