94 Passport EX Data Link Connector?
My Rear Anti Lock Break light is on on the dash, but I cant figure out why. I looked in the haynes manual and it says there is a 3 pin, 12 pin or data link connector under the dash that you can jumper to tell you the trouble codes. I looked and can't find anything like it describes. Anyone know about this?
_uacct = "UA-939292-44";
Originally Posted by passport105
My Rear Anti Lock Break light is on on the dash, but I cant figure out why. I looked in the haynes manual and it says there is a 3 pin, 12 pin or data link connector under the dash that you can jumper to tell you the trouble codes. I looked and can't find anything like it describes. Anyone know about this? < src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-44"; urchinTracker(); </>
Well I found the Data link connector. It is a 3 pin connector located behind a side panel below the driver sidedash. Its just hanging free and you just connect the 1 and 3 pins together wth a wire and turn the ignition to on and count the number of "check engine" flashes. I hadcode 12 which means all is good. Even though all is not good.
</>Edited by: passport105
