I recentley changed the fuel. My rodeo runs great except when i stop gas just flows out of the bottom of the canister filter under the hood. |
if you mean you recently changed the fuel pump.you have the vent hose an evap lines crossed.the fuel tank is not venting properly an tank psi is pushing fuel into the canister,recheck your hoses to the tank
thanks for the advice
Or you're overfilling your tank. Do not top off.
