4wd indication switch
Old Oct 18, 2009 | 03:01 PM
kdfvwman's Avatar
Default 4wd indication switch
On a 1995 isuzu rodeo there is a 2 pole switch mounted on the right side towards the top of the transfer case.
It is used to indicate (light up) the 4wd indication light on the instrument panel.
My question is this: Should it be either a nc (normally closed) switch or a no (normally open) switch?
It should be a normally closed (plunger extended, switch contacts closed)type switch since the actuating linkage in the transfer case is high only in 2wd mode (switch plunger actuated/ pushed in, switch contacts open)and low in 4wd mode?
Benjaminmt
Feb 13, 2011 08:14 PM
jamracer21
Mar 19, 2010 03:28 PM
grone79
Mar 11, 2008 06:36 PM
lightn13
Jun 27, 2005 06:53 PM
DetroitRodeo
Mar 17, 2005 11:46 AM
