2004 Rodeo- Need parts! HELP!
We were told our Rodeo needs both a throttle body and gas pedal for repair. First, is this true, and second, DOES ANYONE KNOW WHERE TO FIND THESE PARTS?????
Right now, it is dead in the driveway, and we are trying to get it going ASAP. Any help on where to find these parts would be so appreciated!
DIY Grass Clock| Researching for this article I came across the Treehugger post on Ustatic's Wall Grass Concept . Researching for this article I came across the Treehugger post on Ustatic's Wall Grass Concept. You must understand this concept before you can digest the Hour///Gras Living Wall Clock. Based on Ustatic's theory that growing grass at home is beneficial this concept clock encourages you to grow either grass or other suitable plants in a stainless steel and glass body frame and hang it on a wall. The hour and minute hand pass over the patch of grass and trim it via their sharpened edges and help maintain a pre-set level of grass-blade length. In case you sow wheatgrass you can consume the trimmings but for any other plant replica techno master watches just dispose of the clippings which pass through the grates at the bottom of the encasement into a slide-out container. On maintenance point of view a watering basin is located at the top right corner of the frame and Ventilation grills run along the top of the structure. Point is��do you need a grass patch in your home? If you do corum horizontal replica watches then are you willing to do the labor? The only benefit I see of this clock is if you're going to grow wheatgrass (or similar); my parents swear by the benefits of consuming it. Designer: J Yu Read the original here: DIY Grass Clock
