Can anyone help me with this issue. The dealer says I ned a high pressure fuel pump which is located at the back of the engine. I have a 2004 3.5l direct injection engine. How hard is this to replace and any ideas where I can find one. The dealer wants $1100 for it. |
RockAuto.com seems to havea Bosch for $452. Although it isn't perfectly clear this is the high-pressure direct injection pump. Can't say how difficult it would be to replace on a 2004, however. Are you sure it won't be covered under the 2005 Isuzu fuel pump recall? Good Luck. NHTSA Campaign ID Number: 05V466000 - <DIV class=recall_data_closed id=closed_15662 style="DISPLAY: none">Recall Date: 10/07/2005 Component: 2004 ISUZU RODEO FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMP Potential Units Affected: 15515 </DIV> <DIV class=recall_data_open id=open_15662 style="DISPLAY: block"> 2004 ISUZU RODEO FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMPRecall Date: 10/07/2005 Summary: CERTAIN SPORT UTILITY VEHICLES THAT HAVE BEEN EXPOSED TO FUEL CONTAMINATED WITH SILICON MAY DEVELOP SMALL PIN HOLES IN THE FUEL PUMP FEED PORT. SILICON HAS BEEN IDENTIFIED IN THE FUEL SYSTEMS OF AFFECTED VEHICLES AND IN CERTAIN FUEL AVAILABLE IN THE REGION OF TYLER, TEXAS. THIS RECALL WILL BE LAUNCHED FOR VEHICLES REGISTERED IN TEXAS AND THE FOUR SURROUNDING STATES: OKLAHOMA, ARKANSAS, NEW MEXICO AND LOUISIANA. Consequence: A FUEL LEAK COULD LEAD TO A VEHICLE FIRE. Remedy: FOR VEHICLES REGISTERED IN THE STATES IDENTIFIED ABOVE, DEALERS WILL PROVIDE A NEW COVER OVER THE EXISTING FEED PORT ON THE FUEL PUMP OR, IF THE EXISTING FEED PORT HAS ALREADY BEEN DAMAGED, DEALERS WILL INSTALL A NEW FUEL PUMP THAT IS EQUIPPED WITH THE NEW COVER. THE NEW COVER WILL BE MADE OF A DIFFERENT MATERIAL. THE RECALL BEGAN ON NOVEMBER 25, 2005. OWNERS MAY CONTACT ISUZU AT 1-800-255-6727. Potential Units Affected: 15515 Notes: ISUZU RODEO </DIV>Edited by: XR400R |
It might still be covered under warrenty if you are still within the warranty period. I think the fuel pump might be considered drivetrain. Factory warranty is 10 years/120,000 miles on the powertrain and three years/50,000 miles on the rest.
Warranty is half for 2nd owner. |
was anyone able to get it done under drivetrain warranty? i need a high pressure fuel pump too for my 04 rodeo direct injection 3.5 liter...
2004 HFP198-01 have 2004 rodeo bad high pressure fuel pump
Originally Posted by dylsha
(Post 46779)
| All times are GMT -5. The time now is 05:28 AM. |
