2003 Rodeo clutch fan
Are you having problems with the coolant fan [img]smileys/smiley5.gif[/img] ? What enging do you have [img]smileys/smiley5.gif[/img] ? The 3.2L fan clutch has been discontued [img]smileys/smiley11.gif[/img] and replaced with the 3.5L DI clutch and you will have to buy both clutch and fan to work [img]smileys/smiley6.gif[/img] . Note that when installing a fan on to the engine there is a blue mark on one of the fan bracket studs and a yellow mark on the clutch, these will need to be matched up [img]smileys/smiley27.gif[/img] or it may cause vibration concerns and the bracket may break [img]smileys/smiley28.gif[/img] .
There are also electric fan options. I think I saw a conversion kit on the independant4x website, it may have been somewhere else for the Rodeo but check them out. It's not to hard to do yourself without a conversion kit either. My mechanic buddy is going to do it on my 99; he explained it andit seemed very easy. When it get's done I will post the process, but some parts from an auto wrecker is all one needs. I would describe how to do it now but I would screw something up for sure.
