| rottman |
Nov 7, 2012 04:28 PM |
2002 Rodeo running problems. please help
i have been trying to fix my rodeo and can not figure it out. its the 3.2 and it ran great. all of a sudden it had no power. when you hit the gas it just boggs down. barley moves. i did the timing belt and timed it but it still does it. im not sure if the cams them self are timed though. i did the belt shouldn't that time the cams too? if not could someone give me directions to do that. i see marks on the back of the camshaft gears but not sure where they are supposed to be. when they pass about 4 times i think i see where they are supposed to be but they are about 2 or three teeth off. would that make a difference. im at a loss right now. I would appreciate any inputs i get. before i took it apart i got these codes. p1312 and p0300 when i did timing they went away. but still ran the same. then after 10 min of idle they came back. no power what so ever. im posting the link i used to time it so you know exactly what i did. im sure i did that part right. seems like something else. Thank you in advance for anyone who could help me. i really appreciate it. http://ww2.justanswer.com/uploads/su...en_updated.pdf
