Alternator or ECM bad???
Hi all,
I have a 1997 Isuzu Rodeo 2wd with a 2.6 4ez1 engine and 5 speed manual trans. I was heading to work last week when the motor sputtered and cut out. I figured the fuel pump gave up the ghost when I didn't hear it cycle when I turned on the ignition key.
Upon getting it towed home I began to troubleshoot the fuel pump before randomly replacing it and found the fuse to the ECM was blown. I replaced it and went and tried to start it and could hear the fuel pump cycle. I proceeded to try and start it which it did momentarily but immediately died and wouldn't restart.
I did a little searching and found where the alternator could be the problem. I disconnected the 4 pin harness, replaced the fuse and she started up and ran fine and was charging the battery although it was only reading about 13.7 volts on my multimeter. I replaced the alternator and all was well until today I had to step on it a little bit to pass in traffic and it sputtered and died. The fuse was blown again so I cut the lead that goes from the alternator to the ECM, replaced the fuse and she started and ran fine.
Is there a way to tell which one is causing the problem? I had also read on a forum about a way to bypass the ECM connection but for the life of me I can't find it. Any elp and or ideas would be appreciated.
Thanks Alan
Thanks Alan
Hi all,
Thanks Alan
Thanks Alan
Might be better to have your original part repaired at upfix.com
Here is the service link
https://www.upfix.com/product-catego...ontrol-repair/
