1995 rodeo black smoke, cel please help
Old Oct 14, 2009 | 03:23 PM
dalep's Avatar
Default 1995 rodeo black smoke, cel please help
I just bought this 1995 rodeo 3.2 auto 2wd, on start up blows black smoke, no power, once warms up cel comes on, runs better not right. cant figure out how or where to pull codes. auto parts store said terminal 1+3 on right of gas pedal but couldnt find. has 197k no funky noises, battery seems to be charging on high side. Thanks
Old Oct 14, 2009 | 06:15 PM
dalep's Avatar
A little more on this flashed codes 44 lean o2 said to check for vaccuum leaks, used carb spray didnt find anything, is there a trend on these i should check
Old Oct 14, 2009 | 06:44 PM
kdfvwman's Avatar
what are the results of a compression test?
Old Oct 15, 2009 | 07:33 AM
dalep's Avatar
Default have not done compression test
Because it cleans up after check engine light comes on I was thinking sensors. I will do comp test tomm. at firehouse today
Old Oct 17, 2009 | 08:26 AM
kdfvwman's Avatar
black smoke/no power/rough/erratic engine running = excessive fuel to air ratio!
Greaser007
Mar 20, 2011 02:22 PM
framptn1972
Apr 3, 2010 08:27 PM
RodeoRaymon
Dec 28, 2007 07:38 PM
d1n0
Jun 12, 2006 03:21 PM
4cefed4
Apr 7, 2006 06:42 PM
