1994 Rodeo with a bad tick
Ok I have a 1994 Rodeo with a pretty bad ticking noise but when I get the rpm's up to 2,200 the ticking stops I've been told by a few guys that deal with isuzu's it's most likely a stuck lifter?? and if it is a stuck lifter what can I do to fix it ohhh and it's the 3.2L V6
Last edited by Anthony08618; Mar 19, 2009 at 04:40 PM. Reason: left out some details
another thing to do before you change the oil put a quart of ATF in your oil. an run the car for 20-30 mins maybe take it for a drive down the highway. ATF has good cleaning property's for varnish "which work well on sludge an stuck lifters. do that then finish changing your oil. an also mabey change your oil a bit short of the normal intervals to help get some more of the sludge out.
get rid of the lifter tick then switch to 15-40 if you want.
the tap is very specific it made the same tapping noise all the time soon as it got to 2,200 on the dot every time the noise would stop back under 2,200 it would start again I found a guy from another isuzu forum that had the same problem come to find out it was the ticking of the timing belt tensioner which according to some people I've talked to is actually pretty common with isuzu vehicles, so here is a video of the tensioner knock http://s550.photobucket.com/albums/ii405/ditchdoc/94%20Trooper/?action=view¤t=TensionerKnock.flv sound anything like yours??? that sounded just like mine!!!!
The ticking that i have is not loud. You really only hear it when you are out side the truck and not when driving. It also goes away when i change the motor oil every 3000 - 4000 miles. The sound comes back within 1,500 miles. I think it is valve train noise and the fact that i have 200,000 miles on the truck. I run 89 octain fuel to keep it running great. I love this truck, it is so well made. 25 miles per gal. smooth 5 speed man, power in any gear, and leather seats. Can't beat it.
I've talked to is actually pretty common with isuzu vehicles, so here is a video of the tensioner knock http://s550.photobucket.com/albums/ii405/ditchdoc/94%20Trooper/?action=view¤t=TensionerKnock.flv sound anything like yours??? that sounded just like mine!!!![/quote] No, nothing like that. wish u luck, is that due to the age or what?
