Looking at 2002 Rodeo
Old 03-27-2021, 10:24 PM
EdNerd's Avatar
Default Looking at 2002 Rodeo
I'm looking at a 2002 Rodeo LS. Using a VIN decoder, I see it has the 3.2L DOHC 6VD1 engine. This one has 168k miles. I know the oil was changed fairly regular, and it has sat for most of the last 3 years.
Questions:
-- How many more miles might this engine be good for?
-- Is this an interference engine?
-- How big of a job to change the timing belt / chain?
-- Whilst in that deep, what else should be done?
Also:
-- It has an add-on package of front bumper, side steps, roof rack, and square hitch receiver. Was that a factory option?
-- The transmission has been either replaced or rebuilt. How do you test a transmission for acceptability?
-- Other than bad rubber (bushings, hoses, etc), what else should I look for?
-- What is a fair test drive for this vehicle?
Thank you!
Old 03-28-2021, 03:04 PM
EdNerd's Avatar
Found some answers here: https://www.ericthecarguy.com/forums...-belt-install/
And here: https://www.2carpros.com/diagrams/isuzu/rodeo/2002
And this guy has a 10-part series on this:
So it's a non-interference engine. And the timing belt is reasonably complicated, but doesn't require pulling off the heads or any such thing. It can be gotten to from the front, so that's a good thing. A bit more complex than my Chevy Aveo, but I did that three times. And the water pump is also in this loop, so do that, too (and of course the idler pulley and belt tensioner). (With my Aveo, the water pump was circular, and you turned it to tension the timing belt. That was a new one on me!)
Still wondering how far this engine might be able to last?? At 163k, is it only halfway home? Or dodging death with every mile?
Old 01-02-2023, 07:17 AM
varunkcar's Avatar
If you cannot find the VIN, try putting your Vehicle Registration mark (VRM) in one of the following links.
FREE and paid both
Mercedes VIN Number Decoder
https://www.vindecoderz.com/ FREE
Old 01-05-2023, 01:18 AM
varunkcar's Avatar
Default Check Your caR Vin Decoder
i am going to tell you a wonderful resource through which you can check and get car history report instantly. All you need to enter Vehicle Identification Number a
Use this website and decode your VIn free of cost Check Your Mercedes Vin Decoder
Old 01-10-2023, 08:55 AM
varunkcar's Avatar
Give this site a try, see if its what you are looking for...I found 2 sites online
or BMW Vin Decoder
melcher
01-20-2023 09:40 AM
jfowlkes
08-24-2012 11:24 AM
tamaforlife
06-03-2012 01:21 PM
cmenchion
03-02-2010 06:20 PM
B20hatch
08-05-2009 09:10 AM
Quick Reply: Looking at 2002 Rodeo
