02 Rodeo LS 6Cyl
Old Aug 16, 2015 | 04:07 PM
Antairus's Avatar
Default 02 Rodeo LS 6Cyl
I Just bought My Daughter a Rodeo.
127k miles. Having a Strange Starting Issue
Things I have done Just as normal Maint.
Replaced Timing Belt, Tensioner, and Idler.
Replaced Drive Belt, Tensioner, and Idler.
Replace Plugs With Correct Champion Plugs.
Cleaned PCV Valve
Cleaned EGR Valve.
This Issue was occurring before I did any of this.
The cars Starts and runs fine, and you can drive it all day no issues.
What happens is when you let it sit for 5 Min's it just cranks and cranks.
It takes several tries to get it started. once it does it runs and drives fine.
If you let it sit for 30 min to an hour it will start right up.
Any Ideas on what it Might Be?
NEUWBEA
May 6, 2010 04:04 PM
nwtraveler469
Aug 25, 2009 12:03 PM
