02 Air Conditioner won't work
I have a 2002 Rodeo w/ 6 cylinder engine. AC will not come on. Blue indicator light on control panel will not light up either. Any ideas?
Thanks. |
You must have checked out the suction pressure if you didn't diagnosed then you should replaced the pressure switch that is attached with dryer, hope that by doing this your problem solved..
