Weber 32/36 conversion
I have a '94 2.3 that I am installing a Weber 32/36 carb in. Need a little help on where vacuum lines go (or which emissions parts can be scraped). If you've done this conversion, picks would be great but any help would be appreciated.
Thanks
disconnecting the vacuum line wouldnot be an advisablething to do on that engine for an added power. Be wary though if youhappen to see a fuel coming out of the vacuum fitting, it might be torn already and the fuel pressure regulator might need to be replaced. Better check for these signs first as it might ruin yourcarb installation
