hey all , I have a 94 pickup with a 10 bolt removable carrier rear end and I want put a posi in it. I have yet to find a co that makes one for it. Anyone know of one? Or what other removeable carrier rear ends Isuzu made that will fit in my rear axle. I was told some rodeo rear ends were interchangeable and some even came with a posi. Any help would be great. Thanks
3 speed what engine do you have??? are you sure it''s a 10 bolt???? the number of bolts is actually how many bolts are in the ring gear not how many are holding the drop out 3rd member in..... get back to me and i can tell you from here where to look and what your options for picking up an LSD rear end are going to be......
It has a 2.3l carb. There is suppose to be an id tag on the axle somewhere but I have yet to find it. How do you id the axle with out the tag or opening it up. Thanks 3speed |
from what i''ve seen the I.D. tags are usually gone..... now that being said there is a MUCH easier way to find out if ANY Isuzu had the LSD rear end.... when you pop the hood there is an "options tag" from what i''ve seen it''s always on the drivers side pretty close to the brake booster look for the code "G80" to be stamped into it..... that "G80" code is the factory options identifier for the LSD rear end..... now then you''ll need to find either a trooper or a pickup with a 2.3 gas engine like yours and look for the tag under the hood..... yank the rear end and it should be plug n'' play [img]smileys/smiley2.gif[/img] just make sure that it''s not a pickup before the 88 year model as those were actually the P''up and anything 88 on was a pickup....... hope this helps
| All times are GMT -5. The time now is 05:39 AM. |
