i have a 92 isuzu pickup regular cab
and my clutch petal was sticking to the floor and the clutch pedal worked fine and never stuck when the engine wasn''''t running so i knew it was the actual pedal and it was something inside the transmission so i dropped the transmission to change the throw out bearing, pressure plate, and put a new clutch in when i looked at the old throw out bearing the pressure plate had been eating away at it so i put a brand new pressure plate, clutch and throw out bearing in it and put everything back together now the throw out bearing does not seem to be be pressing against the pressure plate because i can move the arm the clutch cable attaches to by hand when before i had to use a lot more force and when i press down the clutch it is much easier and then just sticks to the floor when not running it sticks in the same way that it would if the clutch cable was not attached any information and questions are welcome |
Just adjust your clutch cable...ALOT! I had the same problem, and after dropping the tranny like 3 times and replacing all the same stuff, it came down to the clutch cable...
so he rigged it up with some styrofoam and a piece of wood so so i took all that out and put a steel plate in its place and screwed it to the body but the clutch cable has to be adjusted to where it is tight or it will move around and adjust itself but i fixed it the ball that the arm sits on (the arm that pushes the throw out bearing back and forth) wasn''t long enough so i unscrewed it and put a few washers behind it and now it works great |
