| tbirdboomer05 |
May 9, 2009 04:36 AM |
Engine block interchange
I have a 1993 pickup with a 2.3L engine and a 5 speed manual. I was given to me by my uncle because it blew a head gasket and eventually cracked the block and warped the head. I have had the head redone and was in search of a block. I recently purchased one. However, I realized the block was a G200z and not the 4ZD1. Is there any way I can use this block with the head and intake and accessories? I'm sure the transmission will bolt up but I'm unsure about the block. I plan on using a re-ring kit and new main bearings either way. Any help will be greatly appreciated.
