-   Pickup (https://isuzuforums.com/forum/pickup-25/)
-   -   changing 95 pickup brakes and rotors (https://isuzuforums.com/forum/pickup-25/changing-95-pickup-brakes-rotors-1341/)
whitetruck Sep 24, 2007 09:12 PM
i'm in the middle of changing the front brakes. the rotors are warped. I have replacements, but i can't get the 6 bolts off to get to the rotor. i've been using a air impact and still getting nothing.
any suggestions would be great
Edited by: whitetruck
whitetruck Sep 25, 2007 10:59 PM
figured it all out
1TLB Jan 20, 2008 03:46 PM
So what was the issue? </span>
It may help someone out in the future.</span>
MEphenSean Oct 31, 2009 07:43 PM
Help with rotors
So, I hate reviving old threads, but here goes:
How in the world did you get the bolts free to separate the hubs and rotors??? I will absolutely need to drive my 95 Trooper two days from now (tomorrow would be nice), and right now the front wheels are off. Removing the rotor/hub assembly was way more involved than the brake work I've done before on small cars, which normally meant all you had to do to remove the rotors was take a couple of screw out.
Do I really need an impact wrench for this? I don't have one, or an air compressor. Nor do I have the $1000 the shop wanted to replace all four rotors, the pads, and a sticking caliper. Those six bolts aren't budging.
Sean
