-   Pickup (https://isuzuforums.com/forum/pickup-25/)
-   -   94 isuzu pickup charging system issues (https://isuzuforums.com/forum/pickup-25/94-isuzu-pickup-charging-system-issues-36825/)
captmeach7 11-17-2010 01:08 PM
I was given a 94 pickup (2.3 carb manual) about 2 weeks ago and it has some issues. It had a rattling noise that i was told is a throwout bearing. weird thing is that it's stopped rattling after sitting for a few days and not driving. The biggest problem is with the electrical system.
The battery, brake, and o2 lights started flickering and would stay on the other day and then the truck wouldn't start. So i had to have the truck jump started and got it home. The battery was only reading 11V and i could turn the alternator belt with my hand. I loosened the alternator and the belt looked fine, so i tightened the alt. to where i couldnt turn it. I had the battery charged and checked at Oreilly and it was reading 12.6V when i hooked it back up.
I started the engine and it read 14V or so and the indicator lights were off and the stereo worked again. It worked for about an hour of driving. Belt is still tight.
Now the battery is reading 12.11 and dropping when the truck is running unless i rev the engine very high. Should i replace the belt? (maybe the original was stretched?) And i can't seem to find the external voltage regulator to check it. Says left inner fender but i don't know what it even looks like. The pics on the auto parts sites look nothing like what i'm seeing. Any help would be appreciated. Thanks.
davor988 11-24-2010 08:04 PM
Nike Free Run afresh appear a new Air Max 95 Photodejected. As able-bodied as the apple’s a lot of archetypal Nike running shoe appearances,General Ray Ban Sunglasses, Nike Air Max 95 has been adapted endless assuredly admirable plan. This absolution is aswell actual agitative, called “PhotoBlue” can be accepted as to the claimedity of this acrylicing composition Nike Free active shoes,General Ray Ban Sunglasses, blue and atramentous blush acknowledges a little ride of abstruseness, to canyon up. http://www.air-max-wholesale.com/ima...20red-mens.jpg Air Max 2009 Silver Red-Mens Nike Free 2 soles about the data of the deassurance both anatomic and absolutely embodies the appropriates of James sigattributes shoe. Outsole uses geometry and X-appearanced (you can also be beneathstood as the amount chaseed by a aggregate of adaptable sbound advised to banish the force and burden. Groove aheadbottom adaptability to accomplish the best ambit of motion ascendancy, failing multi-absoluteional hawrycartilage architecture custom-built for James to accommodated his aboriginal alpha and cadheree administration in top appeal.Tags: Nike Free 2
