Delete msg. Trouble found. Edited by: blasterman
why delete posts? would it not help anyone else out if they were to have a same or simular problem? that is what this forum is for isnt it? not just solve one problem and then delete the post so no one else can use the same info?
please let me know. personally im in need of info on a 86 pup. i have it all torn apart down to the frame and ready to put new body on her. some thing like this would or could in the future help me out as well as others, so why delete posts? |
To clean up the forum. It appeared no one had an answer for what turned out to be a simple problem.
so how was it solved and what was it? things like the solution would still help someone out.
once a solution is found to a problem it should be posted thread the problem was posted in. that should be a givin. on other forums that ive been a member of for years, we have users to post there findins, whether is solved the problem or not. just to help others out. just because noone here had the answer for you, you decided on not sharing it with anyone. or was the solution caused by neglect and would have made you look like an ass so you deleted it to save imbarrassment. |
