1st Post...Timing Mark Descrepncy
Old 03-12-2008 | 11:07 AM
clearhooter's Avatar
First post here and its with a problem. Aint that always the case?
Bought a Nov 92 Isuzu Pick-up the other day. Had a bad water pump. So when I R&amp;R the WP I naturally decided to R&amp;R the T-belt as well. Got a HAYNES MANUAL to "assist" in the operation. When I set the cam at what the book called the timing mark, a small cast teet on the back cover, the crank lined up between 1:00 and 2:00 against the what the book called the casting line, at 12:00 behind the crank cog. The book showed the cast teet to be also at around 12:00. On the actual truck this mark is around the 2:00 position. There is what appears to be a small notch cut into the back of the cover at the 12:00 position. Is this the mark I need to use instead of the teet? While I do need to check valve adjustment I'd rather not have to pull the cam cover today unless necessary. Any quick help would be appreciated. CH
_uacct = "UA-939292-44";
Old 03-13-2008 | 11:06 AM
Had to get underway on this repair. Pulled the valve cover off and to my surprise the timing marks are set up to fire on #4 NOT #1. It HAS to be this way since there is only one dowel in the cam sprocket and it sets up on #4. Of course the HAYNES MANUAL says its supposed to set on #1. This isn't the first descrepency I've found in a HAYNES MANUAL but I do think it to be the worst. Or do I have somekind of oddball motor?
Old 09-09-2008 | 02:34 AM
daddy's Avatar
i went through the same crap with the hayne book and they are wrong so no you dont have an oddball motor. and the mark for tdc is the one at the very top of the cover. left side in your pic
done2
05-30-2011 02:42 PM
ry0ohki
04-28-2011 09:39 AM
WestCoastKevin
03-22-2010 05:40 PM
ramfan5.9
08-04-2007 09:11 PM
stuwiley
01-13-2005 11:19 PM
