1992 pup wont run right/start
Old Jun 23, 2007 | 11:28 PM
Littlewhitepup's Avatar
The truck wont start. I have the motor on piston # 1 in TDC and the rotor pointing at # 1 wire. The crank pully is set to Zero also. So its all inline and set. I followed the correct firing order. It wont start. It just spins. Ok now when i started to mess with it the rotor was flipped 180. When on TDC it was pointing at # 4. It was running like crap and timing was way messed up. So now i am trying to set it all correct and get it timed correct. Can anyone help to me figure it out. My truck it a 2WD 2.3L. I was recently told that the button has to be on #4 B/c it is the starting cyl. So now it is on TDC and on #4. And not my problem the motor revs high then goes to up and down reving. Anyone have any info for what to do next. What to check replace adj?
Thanks for any info that helps, and feel free to ask me questions to help me figure it out ill answer the best I can.
csanche2
Oct 23, 2008 10:03 PM
98ZuZu
May 3, 2008 03:54 PM
Richard
Jan 20, 2008 01:44 PM
97Hombre
Oct 30, 2007 05:27 PM
97Hombre
Hombre
Sep 30, 2007 09:19 AM
