var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--></>First time I changed the oil on my 1992 pickup 2.3L and I put in too much oil. Didnt think it was too much of a problem until my truck started to leak alot of oil up above the oil filter. Guessing I blew a seal, but dont know which seal. I believe the oil pump is located right above the oil filter. Can anyone help?? < => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> Edited by: sileighty77 |
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> Found out that the oil is actually leaking from a hose right above the oil filter. I was thinking maybe it blew off the nipple it was attached to, but cant seem to find a nipple in the area where the hose will reach. Does anyone know where this hose leads?? |
