Why avoid the New York trigger on Glocks?
The NY trigger makes it much harder to precisely place your shots. That is very bad because it means an increased possibility of a shot going astray and possibly hitting an innocent person--something that you absolutely must not allow, even to save your own life.Then ask yourself why a NY trigger would be safer to carry. Remember that the Glock pistol has 3 automatic safeties, all of which are completely independent of the trigger pull weight. A Glock can only be fired if you fire it. If you are an unsafe gun handler you should not be carrying any gun. If you handle your Glock safely it will never fire accidentally. So I repeat the question: why would a NY trigger make a Glock safer to carry?
_______________ Used Gun Safes |
