Using PIWIS III with Porsche 991.2 (PCM 4.0)
Old Mar 4, 2025 | 09:49 PM
Victor668's Avatar
Default Using PIWIS III with Porsche 991.2 (PCM 4.0)
Common Issue:
Owners of the Porsche 991.2 with PCM 4.0 often mention that the factory shelf lacks enough tilt, causing items like phones or buttons to slide around during hard acceleration.
A more significant issue arises if the PCM head unit is removed. Without it, turning the key and powering on the vehicle will trigger a "System Error" warning on the dashboard due to the system detecting a missing component.
How to Solve It with PIWIS III
The most effective way to resolve this error is by using piwis 3 porsche, Porsche's official diagnostic and coding tool. Here's a simple guide:
1. Open the Gateway Control Unit:
Navigate to:
Gateway → Maintenance/Repair → Current/Specified Configuration
2. Verify PCM Status:
Check the "Actual Installation" list for a red negative sign next to PCM. This confirms the system is expecting the PCM unit, and adjustments are needed to clear the fault.
3. Clear Fault Codes:
Use PIWIS III to delete any saved errors, particularly those displaying on the instrument cluster.
4. Activate Engineering Mode:
For advanced adjustments, enter Engineering Mode in PIWIS III to manually update configuration parameters. It's a good practice to take screenshots of any settings you change for future reference.
Selling a PCM 4.0 Unit:
Unlike previous generations, the VIN cannot be removed from a PCM 4.0. If you're selling your PCM 4.0, the new owner will need to visit a Porsche dealer or authorized workshop with PPN (Porsche Partner Network) access and PIWIS III to unlock and disable component protection.
Additional Findings:
While resolving the system error, I discovered a few helpful insights:
1. PADM Error:
The Porsche Active Drivetrain Mount (PADM) showed no power through the left dynamic mount. This seems to be a common problem and may need to be handled under warranty.
2. Oil Level Sensitivity:
After some spirited driving, the oil level dropped slightly, triggering an oil level warning. Topping off the oil and resetting the message through PIWIS resolved the issue easily.
3. Vehicle Analysis Protocol (VAL):
Out of curiosity, I ran a full Vehicle Analysis and found the car had hit the rev limiter, with double ignition events logged in ranges 1 and 2. While it’s not an issue for me personally, those monitoring DME over-revs (especially on RS models) should pay close attention to this data.
4. PIWIS III Licensing Matters:
Not every PIWIS III tool on the market is fully licensed. An official Porsche dealer in Hong Kong confirmed that using a properly licensed and updated PIWIS III is critical for accurate coding, troubleshooting, and error clearing.
Final Thoughts:
The PIWIS III is an advanced, essential tool for diagnosing, coding, and customizing modern Porsche vehicles. Compared to its predecessor, PIWIS II, the newer PIWIS III brings expanded menus, greater functionality, and enhanced coding options—making it the go-to solution for working on models like the 991.2 with PCM 4.0.
Victor668
Aug 3, 2023 08:43 AM
Victor668
May 8, 2023 03:29 AM
cetmanhd
Sep 6, 2006 08:12 AM
cruser92
Mar 6, 2006 01:40 PM
