-   Off Topic (https://isuzuforums.com/forum/off-topic-9/)
-   -   Troubleshooting Login Issues with John Service Advisor (https://isuzuforums.com/forum/off-topic-9/troubleshooting-login-issues-john-service-advisor-76269/)
Victor668 Aug 20, 2024 08:17 PM
If you're having trouble logging into John Service Advisor on your new T450 laptop with v2 EDL, follow these troubleshooting steps to resolve the issue and successfully access the software.
1. Verify Username and Password
Ensure you’re entering the correct username and password. For example, Jillian Andy faced login issues because they were using an incorrect password saved in a note and confusing it with a different code from a sticker unrelated to the online credentials. Once the correct credentials were used, the login issue was resolved.
2. Check Offline Mode
Confirm whether you are using offline mode or not. If you are in offline mode, make sure you have the necessary credentials for this mode. Switching to the appropriate mode may resolve the issue.
3. Language Settings
Language barriers can be another common problem, especially if the software defaults to a language you're not familiar with, like Chinese. To change the language to English, navigate to the software settings and find the language option. Select English from the list to switch the text to your preferred language.
Summary
To fix login issues with John Service Advisor:
- Verify your username and password.
- Check if you're using offline mode and have the correct credentials.
- Adjust the language settings if the software is not in English.
If you continue to face difficulties, customer support is available to assist you. Feel free to reach out if you need additional help. With patience and the right approach, you can resolve these issues and fully utilize your John Service Advisor software.
