How to Convert AVI to WMV on Mac
Why should you convert AVI to WMV?
Both the AVI and WMV format are the popular video format all around the world. AVI (Audio Video Interleave) is first released by the Microsoft. AVI files always in high quality, but the files’ size is too large. We always find the hard disk is not enough for storing numbers of files. WMV files, at the same time, have a higher video quality and smaller size. And what’s more, WMV supported by a great number of software. A common task that arises for Mac users is to convert AVI to WMV which can be accomplished by the Video Converter for Mac easily and quickly. How to use this converter to convertAVI to WMV? This is a guide for Mac users. If you need to convert on Windows OS, you can go to the Video Converter guide for more details. Step1 Run the Video Converter for Mac Find the downloaded DMG files in your library and double click the files. Then copy the app to the application folder or anywhere you want. Step2 Load the files to prepare the AVI to WMVconversion. Find the flies in your library and drag them to the main interface directly, or you can choose to load files as below: add video files < Import < File < Menu Step3 Select WMV as the output format Next, click the “output setting” icon and find the WMV format under the list of Common Video. Sometimes, you can choose your device or apps as the output format. Even you can find it in the Recent Use if you have converted before. Step4 Convert AVI to WMV on Mac Finally, click the “Start” and wait a few seconds, then you can see the whole converting progress and get the converted files later. Tips for better converting AVI to WMV on Mac: 1 The program is designed for Mac OS X 10.5 or above (Lion included). 2 Capture the screen may be a good choice while you previewing the source file. 3 The Estimated Size shown on the main screen maybe helpful for you. Try to download and convert AVI to WMV now? Or get more functions and features of the Video Converter for Mac: |
