Can Craftmatic Bed Stop Snoring?
Old Nov 25, 2011 | 06:10 AM
boranmeet's Avatar
Default Can Craftmatic Bed Stop Snoring?
During sleep, the muscles in the roof of the mouth, tongue and throat relax as all other muscles do. But there are instances when the tongue, tissues of the throat such as the uvula become relaxed and collapsed altogether that they partially obstruct the airway, causing vibration every time air passes through the throat. As the airway gets narrower, so the tissue vibration also increases, causing the snoring to get louder.
Old Nov 28, 2011 | 05:08 AM
Marry love's Avatar
Get a breathing machine or get that laser surgery to cut out that the floppy skin. This is a serious health issue and should be fixed.
Old Nov 13, 2013 | 12:26 AM
ash1990's Avatar
There are measure several sensible reasons why the tongue and different tissues block the airway and a few of them are measure enlarged tonsils, vast adenoids or tongues or swollen nasal passages attributable to cold or allergies. however one among the foremost elements that cause snoring is that the sleeping position. Sleeping on the rear once more may end up within the tissues within the throat to slip back because the muscle tissue take it straightforward, a state of affairs that prospects probable to snoring.
______________________
Total Knee Replacement Surgery in Australia
Old Nov 24, 2013 | 11:04 AM
alanauer's Avatar
Sure -- during delivery -- if it falls on you and kills you.
Old Feb 23, 2014 | 01:34 AM
rinaric15's Avatar
This is the time when Craftmatic bed comes into the scene. Because it is adjustable, a Craftmatic bed can be transformed into relaxing and comfortable positions to support the head, neck, shoulders and other parts of the body such that the airways are cleared of any blockage from the tissues.
Vancouver Sleep and Breathing Center suggests elevating the Craftmatic bed at 30 degrees to minimise the force on the diaphragm and keep the airway open.
Raising the Craftmatic bed may also help keep the tongue from collapsing against the uvula.
Therefore, Craftmatic bed may be able to stop snoring if the cause is improper sleep position. However, in cases where there is other contributing factors such as obesity and blocked nasal passages, Craftmatic bed may only provide a little help. It will be better if the snorer goes for a comprehensive anti-snoring plan such as regular exercise and quitting smoking and couple it with good night sleep with a Craftmatic.
http://www.1st-care.org
Rina Riccobono
boranmeet
Nov 28, 2011 05:08 AM
boranmeet
Nov 25, 2011 06:08 AM
samsonscott
Nov 5, 2011 03:58 AM
christennn
Oct 21, 2011 02:26 AM
christenn
Oct 20, 2011 11:37 AM
