-   Oasis (https://isuzuforums.com/forum/oasis-24/)
-   -   hub assembly (https://isuzuforums.com/forum/oasis-24/hub-assembly-2468/)
neo_isuzu Oct 28, 2008 10:56 PM
How do you remove the hub and rotor assembly on an Isuzu Oasis? tnx..
________________
neo_isuzu16513212
kurtdaniel Oct 28, 2008 11:01 PM
Remove the clip first from the cv axle at the center of the hub to remove the assembly in 1 piece.. then remove the screws so that the rotor should pull off..good luck..
[img]smileys/smiley11.gif[/img][img]smileys/smiley2.gif[/img][img]smileys/smiley12.gif[/img][img]smileys/smiley14.gif[/img]
hp?act=post&do=rehp?act=post&do=re
kurt daniel, CRE
rum/forumdisplay.php?f=1/key_/</font>
neo_isuzu Oct 28, 2008 11:02 PM
ok..tnx much..ill try it...
