will a supercharger kit fit in a stock 2.2 engine and how much boost can i safely run without blowing the engine
If the supercharge says it fits 2.2L then you should have any problems and boost is pretty much how much power will be added for example my 87 F150 supercharger added 6-7psi of boost an about 80HP so the supercharger should come setup to only putout the amount your engine can safely handle, but i'm not an expert.
Mike < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44"; urchinTracker(); </> |
| All times are GMT -5. The time now is 04:03 AM. |
