News, Updates and Announcements Stop in here to get the latest on IF happenings! Tips and tricks for site use can also be found here, just take a look...
Isuzu 4hf1-1engine ECM type
Old 08-14-2016, 08:02 PM
Kobz's Avatar
Default Isuzu 4hf1-1engine ECM type
im working on isuzu 4HF1-1 engine. It just wouldnt start after it was parked for just 1month. It cranks normally but doesnt run. Checked and found no fuel getting to the injectors from the pump. Because no power out from the magnetic valve wire harness in rotary pump. tried to retrieve the engine diagnose light in dash bord but no light flash codes at all, (no engine check light appeared) checked the ECM, good conditions no burn inside. I may be wrong but i think there's no constant power supply to the ECM. But All the fuses and relay ceck out fine. the ECM found under the compartment box in front. and has 4 multi plug connectors. Can anyone help me please?
darellkonner
01-17-2012 10:16 PM
lennart
09-23-2011 11:49 PM
rasa
02-01-2011 03:14 AM
tractng
09-27-2010 01:06 PM
rod2004
04-13-2007 04:40 PM
Quick Reply: Isuzu 4hf1-1engine ECM type
