Trooper Conversion help
Old Jan 9, 2008 | 08:52 AM
swamp trooper's Avatar
I have replacedmy 89Isuzu Trooper power train withGM and Dodge equipment. The drive train is still mostly stock and the 4.55 differential gears are much too high. Instead of retro-fitting new axles, I am wondering if Isuzu makes lower gears(2.90,3.10,3.73 etc) to work with the 3speed GM Turbo 350 Tranny and Dodge transfer case I have installed. Drive shafts have been made to fit the stock axles and I don't want to have to redo them to match a new one. I didn't think the stock gears would be a problem whenI thought out the conversion...........oops! It now tachs. 2600RPM at 55MPH, juuuuust a bit much for on-road use.I would greatly appreciate your insight..........................Scott
memphisfuk
Exterior
Feb 22, 2008 02:48 AM
mark
Dec 31, 2007 09:12 AM
hokiehoo
Mar 15, 2007 08:10 AM
mizunosan
Feb 26, 2007 03:33 AM
dinenasty
Pickup
Aug 1, 2006 05:18 AM
