TOD LIGHT OFF - CHECK ENGINE LIGHT ON
Old Mar 22, 2008 | 11:27 AM
collyswamper's Avatar
A few weeks ago I had a flashing Check light on my TOD system to go off. I put the 4WD system through its paces and the flashing TOD light went away. Just a cuople of days later - the check engine light came on and I took the Trooper to an auto parts store and got the following readings:
P0128 - coolant temp always low
P1404 - EGR valve stuck
P0405 - voltage signal EGR sensor A too low
I replaced the EGR valve about 12 months ago. - Is it possible for it to go bad so quickly?
Am I dealing with an electrical problem? a short circuit or something?
_uacct = "UA-939292-44";
rmac
Mar 14, 2021 03:50 AM
pmannlein
Oct 31, 2010 08:21 PM
04RODEO
Jun 11, 2008 10:28 AM
lashby
Jun 18, 2007 09:09 PM
