isuso nn 2010 problem
Old Nov 30, 2023 | 02:53 PM
vitor24's Avatar
Default isuso nn 2010 problem
Good afternoon, I have an Isuzu nn 2010 3.0 150cv I bought it new, I never had any problems, it has 177m km.. It recently started to heat up, the following symptom appears the car goes to 90 degrees as soon as I turn off the car the temperature does not always drop to zero, if it is at 0 the temperature goes to 90 degrees if it is 1/4 it rises to 110 degrees.. a thermostat was installed, checked the water pump.. shouldn't the temperature in the quadrant always return to 0 when the car is turned off?
jhonny.drift
Jun 18, 2012 11:23 AM
kramer1929gone
Sep 9, 2009 04:30 AM
dansreply
Sep 11, 2008 02:46 AM
Markr
May 29, 2008 01:27 PM
jhines
Apr 3, 2006 06:29 PM
