How difficult is it to change a 2.2L to a V6
My block has a hole in it and I can't find a replacement. Suggestions?
No once you've change one u-joint they are all much the same. Once you get into the bigger ones like on the hwy tractors things become a bit more difficult but on a jeep you should be good.
_________________________ Epicuren |
