-   IF Help & Suggestion Center (https://isuzuforums.com/forum/if-help-suggestion-center-12/)
-   -   engine overheat with new thermostat but not when removed (https://isuzuforums.com/forum/if-help-suggestion-center-12/engine-overheat-new-thermostat-but-not-when-removed-74158/)
amytre Feb 13, 2016 08:41 AM
I have a 2.2 with a new head gasket, rebuilt head, water pump. The issue is that the engine runs hot with my new and old thermostat. The antifreeze is cool be but engine hot, it seems like was it restricted. Here's the kicker when I remove.the thermostat it run just.fine what can cause the problem
Ryan Mueller Apr 3, 2016 12:12 PM
you have a blockage somewhere. coolant only runs through the thermostat one way (like a check valve) so when you remove it the coolant is allowed to flow backwards through the engine which is why your not overheating without one.
