Driver Power Window Not Working
Old 11-29-2007, 03:13 PM
mckay129's Avatar
Hey everyone,
A couple of days ago the driver side window of my 1998 Isuzu Rodeo ceased to work. It is stuck in the down position. All the other windows in the car work. I checked the spark plugs and they are all working fine. The window has never given me any problems, never had trouble working or anything. The window does not make any sound or try to go up at all when I push the button. What the heck is wrong!
Any help with this would be greatly appreciated.
-Dan
Old 01-14-2008, 09:36 PM
ChernerParts's Avatar
What you may be experiencing are the clips that attach the regulator* to the window itself are broken.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
urchinTracker();</>
*: The regulator is what translates the circular motion of the window motor into the vertical motion of the window going up and down.
Unfortunately, the clips that are attached to the glass are sold as such. Not separately. Not too hard to get a hold of, a large junkyard ought to have a window. If not, PM me your vin and zip code and I can quote you a shipped price, or forward you back a part number and a good price for your local dealership to attempt to match.
Old 09-25-2009, 04:57 PM
rowdyrodeo98's Avatar
yes i have the same problem but it roll down with power fine seemed like normal but wouldnt go up, all other windows work perfect using driver door switchs except driver wont go up, any ideas
Old 10-22-2009, 09:36 AM
lovely09's Avatar
What about a new window regulator?Have you try to check it?
Old 10-31-2009, 11:35 AM
mexVella73's Avatar
Default Driver Power Window Not Working
I own a 1999 Saab 95 and the window washers do not work, however the washers for the headlights still operate. Could you give me some advice on this matter please. Thanks for your help.
Old 11-21-2009, 03:53 PM
thomas.cena09's Avatar
Default Thanks
Thanks for providing information about this. This was really helpful for me.
Old 11-21-2009, 03:55 PM
Default I will try
If I find any information about you people problems, i vl surely help you and leave message here.
  #8
Old 11-25-2009, 05:59 PM
Algopsy09's Avatar
Tried the img thing just as it was shown, but not doing anything.These are pics that are on my computer at home and nowhere on the internet, would that make a difference ?
  #9
Old 11-25-2009, 10:32 PM
srf64's Avatar
2002 trooper driver and passenger window going up and down slow. which would be bad. the motor or the regulator. when using the automatic mode of driver side it stop and then i have to hit it again to finish.
  #10
Old 11-27-2009, 09:58 AM
nelson.jones07's Avatar
Find the solution on you tube videos also in several websites, if you can't leave message I will search and leave links for you.
Quick Reply: Driver Power Window Not Working
