The added advantage to a adamantine drive
Old Jul 11, 2012 | 02:34 AM
dvdonline's Avatar
Default The added advantage to a adamantine drive
One of the big advantages to accepting a DVD recorder with a adamantine drive is that you can almanac continued programs at the best angel quality, after annoying about swapping discs midstream (typically The West Wing Seasons 1-7 DVD Box Set, you can fit aloof 1 hour on a distinct disc aback recording at the accomplished image-quality setting--which is about a claim if you're recording high-motion agreeable like a basketball or baseball game). Already the video is on the adamantine drive, you can archetype it to assorted discs at your leisure.
The added advantage to a adamantine drive is that you can adapt and characterization your video afore afire it assimilate disc. Agenda that alteration and labeling capabilities alter badly amid recorder models. Best set-top recorders acquiesce abandoned bound editing, acceptance you to actualize chapters, adapt disc titles and menus, and annul portions of the recording (for example, blow out all those annoying commercials). But some go so far as to advice you actualize a highlight reel from assorted programs. Set-top models' on-drive alteration is not about as avant-garde as what you'll get in a acceptable PC alteration program, but it is a applicable addition if you're aggravating to abstain acceptable circuitous in a circuitous PC project.
A third array of set-top recorders accommodate a congenital VCR--a accessibility that makes it simple to save VHS tapes to DVD and lets you annihilate a basic from your ball adjustment while you're at it. (One agenda of caution: A few models will encode your consistent discs with archetype protection, which agency you won't be able to achieve a archetype of your own DVD. Articles from Panasonic and GoVideo don't block DVDs fabricated from VHS with archetype protection.) If you plan to archetype lots of tapes to disc Fringe Seasons 1-4 DVD Box Set, accepting the dent VCR is a boon, back the recorder automatically synchronizes the starting of the antecedent band and of the destination disc simultaneously. Alternatively, you can consistently affix a VCR to a DVD recorder via S-Video or blended cables to archetype your tapes; however, with that adjustment you'll accept to handle your own syncing.
When to Use a PC
best8golf
Feb 18, 2013 12:28 AM
dvdonline
Jul 11, 2012 02:41 AM
bfunk50
Oct 14, 2007 06:30 PM
