-   IF Help & Suggestion Center (https://isuzuforums.com/forum/if-help-suggestion-center-12/)
-   -   91 P'up 2.3l No Fuel to Carburetor (https://isuzuforums.com/forum/if-help-suggestion-center-12/91-pup-2-3l-no-fuel-carburetor-76421/)
lawsonsbarn Apr 19, 2025 01:52 PM
I have a very unusual situation with my pickup. It started with crank no start. After replacing the fuel filter and a couple of hoses it still would not start.I removed the fuel pump and tested it-good. Checked the push rod for pump-good, checked the camshaft for wear-good. It has appr. 7/32" or 5.5mm of lift. I'm at my wits end with this thing. Has anyone ever seen this? Any help will be greatly appreciated.
