which way to go
this is for a 1991 pickmup 2.3
I hope that some one can help me figure this out. 1. all turn signals and 4way have worked properly for quite a while 2. now they are doing the following: a. left turn signal front and back work correctly. b. parking lamop on left works correctly. c. right turn signal does not work . at either location. d. only right sinal lamps work when 4way flasher switch is depressed :confused::confused::confused::confused::confused: HELP PLEASE Thank You rnlajunta |
