transmission check light
Old 03-28-2006, 05:56 PM
mblpg's Avatar
can anyone help!! recently had heads skimmed on 95 trooper, all rebuilt fine, drove around for 2 hours with no trouble, then trans check light came on, this caused the trooper to slow down and loose power, also caused engine to get hot,topped upauto gearbox oil, but made no differance, now when ever it changes to second gear the light comes on and same problems, Has anyone come across this before? Any suggestions would be most welcome!
Cheers Mick
Old 04-27-2006, 02:57 PM
Patrick's Avatar
Super Moderator
is it OBDII?
Old 04-27-2006, 08:49 PM
mblpg's Avatar
No, its on a N plate so not OBD11, still got same problem and its running very ruff now all the time cant seem to find anything wrong with it though, bit of a strange one can only think mabey ECU?
Old 04-28-2006, 04:31 PM
ISUZUGURU's Avatar
Super Moderator
WHEN THE TRANS LIGHT COMES ON THE TCM GOES INTO A BACK UP MODE,AN TAKES OFF IN 3RD GEAR,AN MAIN LINE PSI INCREASES TO PREVENT ANY SLIPPING,GET THE CODE CHECKED ...PROABLY SOMETHING UNHOOKED FROM THE HEAD JOB.OR LOSE OF RPM SIGNAL TO THE TCM.I WOULD TAKE IT TO YOUR ISUZU DEALER,FOR THE PROBLEM LET THEM DIAG IT.ANYONE ELSE MAY NOT HAVE THE PROPER INFO ABOUT.ESP TRYING TO PULL CODES FROM IT
Old 06-06-2006, 01:32 AM
natronone's Avatar
I have a similar problem in my Rodeo. Whenever I shift into "L" the check trans light comes on and I get the same behavior (starts in 3rd). If I turn it off and turn it back on it resets and acts fine while in "D". It seems to be some type of tranny electrical switch malfunction.
sammie white
09-29-2011 10:50 AM
spearbang
08-11-2008 04:59 PM
DarkSideofWill
I-Mark
01-25-2008 12:56 PM
mblpg
04-01-2006 11:06 PM
myleshoy
02-02-2006 01:35 AM
Quick Reply: transmission check light
